Dwarf Technical Specs
The MOD Dwarf when powered up
Technical specs
  • length: 105 mm
  • width: 202 mm
  • height: 54 mm
Processor
  • RockChip PX30 CPU:
    • CPU family: ARM A35
    • Platform bit depth: 64 bit
    • Cores Clock: 4 x 1.3GHz
    • Memory: 1 GB RAM
    • Flash Storage: 8 GB
Audio
MOD Dwarf back view showing all its ports.
    • TRS connectors Unbalanced
    • input adjustment between -12dB and +35dB, adjustable in 0.5dB steps
    • Input impedance 1 MΩ
    • TRS connectors Balanced
    • Volume Control: 0dB to -127dB, adjustable in 0.5dB steps;
  • Headphone output:
    • 3.5mm TRS connector
    • Digital volume control from -33dB to +12dB, adjustable in 3dB steps
USB
  • USB Host
    • Connector: Type-A
    • Standard: USB 2.0
  • USB Device
    • Connector: Type-B
    • Standard: USB 2.0
Device Controller
  • 1x 2.9" LCD display
  • 3x endless knobs
  • 3x performance buttons (that allow you to switch between control assignments pages) (backlit with colour LED's)
  • 1x menu button (backlit with colour LED's)
  • 3x footswitches with coloured indicator LED's
Peripherals
Software
The MOD Dwarf runs the MOD runs the latest Operative System. Support for the MOD Dwarf was added to the MOD OS on version 1.10.
