Dwarf User Guide
The MOD Dwarf when powered up
AUDIO OUTPUTS WARNING !
POWER ADAPTER WARNING !
  • Use supplied adapter only
Concepts and Modes
400px
The concepts and modes of the MOD Dwarf are in short the names and labels that we use to call functions and views on the MOD Dwarf.
USB Host port (USB port A)
Applications: USB MIDI Host, USB Bluetooth (with dongle), USB Flashdrive (making device backups)
MIDI I/O
The MOD Dwarf also supports "old-school" MIDI devices. For that, the Dwarf uses two TRS 3.5mm ports. These can be directly connected to other devices using TRS MIDI Type-A, using a 3.5mm TRS cable. It is also possible to connect a dongle to convert it to DIN-MIDI. This dongle should be of the "Type A" and will allow you to hook up your "old school" DIN-MIDI devices. Make sure to use the right type of dongle!
  • Knob: turn for precise value change, hold and turn for coarse value change;
  • List: turn left to open list and select prev item, turn right to open list and select next item, click to open/close overlay, hold then turn then release to open the list then change the value then immediately close the list.
Menu button
To the left of the Dwarf's screen, you can find the Menu button.
You can edit the Menu Items showcased on this menu on the Settings of your MOD Dwarf. (picture with close up of this button)
Display
Control Mode
The MOD Dwarf allows you to switch between 8 pages and 3 subpages. This means that each of you the 3 endless knobs on your Dwarf can be assigned up to 24 parameters. The footswitches B and C can be assigned up to 8 parameters each.
Navigation Mode
(image similar to the top one but with Navigation Mode)
Tool Mode
The MOD Dwarf has a built-in chromatic tuner. Both inputs can be used as the tuner input, to select between them push the right footswitch.
If you see a question mark on the tuner screen, it means the MOD Dwarf is not receiving any input or the input levels are too low. (image of the screen with a question mark)
Tempo
The MOD Dwarf has a built-in tool called "Tempo". This tool allows you to define the main tempo settings in your MOD Dwarf.
Turning the right endless knob will scroll all the available options of Clock Source (Internal, MIDI, or Ableton Link). Note that when your clock source is MIDI the Footswitch C changes its function to be a toggle activating and deactivating the MIDI sync.
On this tool, Footswitch C is assigned to start and stop the tempo tool.
  • Off: below -40dB
  • Red: between -1dB and 0dB
Dwarf gain staging
WIP--------
