Dwarf Technical Specs
Technical specs
- length: 105 mm
- width: 202 mm
- height: 54 mm
Processor
- RockChip PX30 CPU:
- CPU family: ARM A35
- Platform bit depth: 64 bit
- Cores Clock: 4 x 1.3GHz
- Memory: 1 GB RAM
- Flash Storage: 8 GB
Audio
- TRS connectors Unbalenced
- Input impedance 1 MΩ
- TRS connectors Balenced
- Volume Control: 0dB to -127dB, adjustable in 0.5dB steps;
- Headphone output:
- 3.5mm TRS connector
USB
- USB Host
- Connector: Type-A
- Standard: USB 2.0
- USB Device
- Connector: Type-B
- Standard: USB 2.0
Device Controller
- 1x 2.9" LCD display
- 3x endless knobs
- 3x performance buttons (that allow you to switch between control assignments pages)
- 2x footswitches with color LEDs
- 1x footswitch (that allow you to switch between control assignments pages for the footswitch A and B)
Software
The MOD Dwarf runs the MOD runs the latest Operative System. Support for the MOD Dwarf was added to the MOD OS on version 1.10.
