Dwarf User Guide
AUDIO OUTPUTS WARNING !
POWER ADAPTER WARNING !
- Use supplied adapter only
USB Host port (USB port A)
MIDI I/O
The MOD Dwarf also supports "old-school" MIDI devices. For that, the Dwarf uses two TRS 3.5mm ports. These can be directly connected to other devices using TRS MIDI Type-A, using a 3.5mm TRS cable. It is also possible to connect a dongle to convert it to DIN-MIDI. This dongle should be of the "Type A" and will allow you to hook up your "old school" DIN-MIDI devices. Make sure to use the right type of dongle!
Parameter type Trigger - turn left, turn right or click to trigger Toggle - turn left for off, turn right for on, or click to toggle List - turn left to open list and select prev item, turn right to open list and select next item, click to open/close overlay, hold then turn then release to open the list then change the value then immediately close the list Knob - turn for precise value change, hold and turn for coarse value change
Menu button
To the left of the Dwarf's screen, you can find the Menu button. This button opens the menu, which allows you to open settings, save your loaded pedalboard, and access the three Menu Items that you can define in the settings of your device. (picture with close up of this button)
The MOD Dwarf has 3 buttons that allow switching between the three subpages of assignments for the encoders. (picture with close up of these buttons)
The MOD Dwarf has three footswitches. These footswitches allow you to execute multiple functions by simply pushing each of them or by pushing two of them simultaneously.
Footswitch A
Footswitch A on the MOD Dwarf allows you to cycle between views in a mode.
In control mode, it cycles through the actuator assignment pages.
In navigation mode, it switches between the list of pedalboards and the list of snapshots.
In tool mode, it cycles through the available tools.
Footswitches B and C
In control mode, these footswitches can be assigned to any plugin on your pedalboard. In navigation mode, they can be used to scroll up (footswitch B) and down (footswitch C). In tool mode, they are used to control the functionality of the active tool.
Accessing Tool
Accessing Pedalboards
Display
Dwarf gain staging
WIP--------
The MOD Dwarf allows you to switch between 8 pages and 3 subpages. This means that each of you the 3 endless knobs on your Dwarf can be assigned up to 24 parameters. The footswitches A and B can be assigned up to 8 parameters each.
