Dwarf User Guide
AUDIO OUTPUTS WARNING !
POWER ADAPTER WARNING !
- Use supplied adapter only
USB Host port (USB port A)
Menu button
Footswicth A
Footswicthes B and C
Accessing Tool
Accessing Pedalboards
Display
- width: 202 mm
- length: 105 mm
- height: 54 mm
Dwarf gain staging
WIP--------
The MOD Dwarf allows you to switch between 8 pages and 3 subpages. This means that each of you the 3 endless knobs on your Dwarf can be assigned up to 24 parameters. The footswitches A and B can be assigned up to 8 parameters each.
