Dwarf User Guide
The MOD Dwarf when powered up
AUDIO OUTPUTS WARNING !
POWER ADAPTER WARNING !
  • Use supplied adapter only
USB Host port (USB port A)
Menu button
Footswicth A
Footswicthes B and C
Accessing Tool
Accessing Pedalboards
Display
  • width: 202 mm
  • length: 105 mm
  • height: 54 mm
  • Off: below -40dB
  • Red: between -1dB and 0dB
Dwarf gain staging
WIP--------
The MOD Dwarf allows you to switch between 8 pages and 3 subpages. This means that each of you the 3 endless knobs on your Dwarf can be assigned up to 24 parameters. The footswitches A and B can be assigned up to 8 parameters each.
