Dwarf Technical Specs
Technical specs
- length: 105 mm
- width: 202 mm
- height: 54 mm
Processors
- RockChip PX30 CPU:
- CPU family: ARM A35
- Platform bit depth: 64 bit
- Cores Clock: 4 x 1.3GHz
- Memory: 1 GB RAM
- Flash Storage: 8 GB
Audio
- input adjustment between -35dB and +12dB Line level;
- TS connectors;
- Input impedance 1 MΩ
- Programmable Fine Adjust Gain Amplifier: ± 12dB Gain, 0.5dB step; (clarify this)
- TRS connectors
- Balanced and unbalanced modes
- Volume Control: 0dB to -127dB, 0.5dB step;
- Headphone output:
- 3.5mm TRS connector
- Digital volume control from -33dB to +12dB
USB
- USB Host
- Connector: Type-A
- Standard: USB 2.0
- USB Bluetooth
- USB Wifi
- USB MIDI
- USB Device
- Connector: Type-B
- Standard: USB 2.0
- USB Ethernet Connection
- USB Mass Storage (used for updates)
- USB MIDI
Controllers
- 3 endless knobs
- 3 performance buttons (that allow you to switch between control assignments pages)
- 2 footswitches with color LEDs
- 1 footswitch (that allow you to switch between control assignments pages for the footswitch A and B)
Plugin Control
- 3x endless knobs
- 24 parameters can be assigned to each of the endless knobs
- 2x Footswitches
- 8 parameters can be assigned to each knob
Peripherals
Software
The MOD Dwarf uses a Linux operating system with LV2 plugins to define virtual pedalboards.
