File handling
Getting Started
How to upload a file
Available file types
Audio Files
- aif
- aifc
- aiff
- au
- bwf
- flac
- htk
- iff
- mat4
- mat5
- oga
- ogg
- paf
- pvf
- pvf5
- sd2
- sf
- snd
- svx
- vcc
- w64
- wav
extra through ffmpeg:
- 3g2
- 3gp
- aac
- ac3
- amr
- ape
- mp2
- mp3
- mpc
- wma
Audio Loops
Audio Recordings
Audio Samples
Audio Tracks
Impulse Response Files
- aif
- aifc
- aiff
- flac
- w64
- wav
Instruments
Hydrogen Drumkits
SF2 Instruments
SFZ Instruments
MIDI Files
For MIDI files basically.
- mid
- midi
MIDI Clips
MIDI Songs
Audio Files
Simple plugin that plays a sample on every received note (without changing pitch). One crashing bug was recently found, so plugin is only available as beta for now.
MIDI Files
Impulse Responses
Stereo LSP Impulse Responses.
A plugin for reverb IR files from the LSP suite. Possible maximum size of IR depends on the device (Duo cannot handle much, Duo X is much better). MOD port in development, available as beta for now.
Instruments
