File handling
Getting Started
How to upload a file
Supported types of files
Audio Files
Audio Loops
Audio Recordings
Audio Samples
Audio Tracks
Impulse Response Files
- aif - aifc - aiff - flac - w64 - wav
Instruments
Hydrogen Drumkits
SF2 Instruments
SFZ Instruments
MIDI Files
For MIDI files basically.
- mid - midi
MIDI Clips
MIDI Songs
Audio Files
Impulse Responses
For Reverb IRs, we are investigating using one of LSP plugins. Coming soon.
Instruments
MIDI Files
