File handling
Getting Started
How to upload a file
Supported types of files
Audio Files
Audio Loops
Audio Recordings
Audio Samples
Audio Tracks
MIDI Files
MIDI Clips
MIDI Songs
Impulse Response Files
Reverb IRs
Speaker Cabinets IRs
Instruments
Hydrogen Drumkits (h2drumkit)
SF2 Instruments (sf2)
SFZ Instruments (sfz)
Audio Files
Currently in development, available as beta for now. Only synced with host transport, but this will change. Expected release in March
Impulse Responses
For Reverb IRs, we are investigating using one of LSP plugins. Coming soon.
MIDI Files
- MIDI file player by falkTX, currently in beta, under development (only synced with host transport, for now) expected release in March
