File handling
Getting Started
How to upload a file
Supported types of files
Audio Files
Audio Loops
Audio Recordings
Audio Samples
Audio Tracks
MIDI Files
MIDI Clips
MIDI Songs
Impulse Response Files
Reverb IRs
Speaker Cabinets IRs
Instruments
Hydrogen Drumkits (h2drumkit)
SF2 Instruments (sf2)
SFZ Instruments (sfz)
IR Loader
Audio File
How to play the file
