File handling
Getting Started
Starting on version 1.10 of MOD firmware it is possible to store files inside your MOD device and access them in multiple different ways according to the plugin where they are can be used. Check here how to access and check the files stored inside your MOD device. ----------> link with File Manager section on WebGUI page of the wiki
How to upload a file
Supported types of files
Audio Files
MOD devices file manager divides your audio files into 4 different categories: Audio Loops, Audio Recordings, Audio Samples, and Audio Tracks. For each of these categories, there's a different folder. It is important that you store your audio files into the correct folders since different plugins have access to different folders.
Audio Loops
(loopable audio files...kind of like Ableton...drum patterns, etc)
Audio Recordings
(files recorded inside the device)
Audio Samples
(audio snippets. for example a snare drum sound)
Audio Tracks
(meant to store for example backing tracks)
MIDI Files
MIDI Clips
MIDI Songs
Impulse Response Files
Reverb IRs
Speaker Cabinets IRs
Instruments
Hydrogen Drumkits (h2drumkit)
SF2 Instruments (sf2)
SFZ Instruments (sfz)
IR Loader
Audio File
How to play the file
