Dwarf User Guide
The MOD Dwarf when powered up
AUDIO OUTPUTS WARNING !
POWER ADAPTER WARNING !
USB Host port (USB port A)
Left endless knob actions
Right endless knob actions
Performance buttons
Instant snapshots
Pagination
Display
Left Display
Right Display
  • width: 163 mm
  • length: 188 mm
  • height: 63 mm
  • Off: below -40dB
  • Red: between -1dB and 0dB
  • 1st page: red
  • 2nd page: yellow
  • 3rd page: green
True Bypass (should we take this out or refer to the "normal" bypass?)
