Dwarf User Guide
AUDIO OUTPUTS WARNING !
POWER ADAPTER WARNING !
USB Host port (USB port A)
Left endless knob actions
Right endless knob actions
Performance buttons
Instant snapshots
Pagination
Display
Left Display
Right Display
- width: 163 mm
- length: 188 mm
- height: 63 mm
- 1st page: red
- 2nd page: yellow
- 3rd page: green
