Duo Technical Specs
Technical specs
MOD Duo dimensions in mm
  • length: 186 mm
  • width: 160 mm
  • height: 75 mm
Processors
  • A20 CPU:
    • Dual Core ARM A7 1.0GHz
    • 1 GB RAM
    • 8 GB Flash Storage
  • Audio CODEC:
    • Manufacturer: Cirrus Logic
    • DAC: 104dB dynamic range, -90dB THD+N
    • ADC: 104dB dynamic range, -95dB THD+N
    • 24 bit / 48 kHz AD/DA
Audio
MOD Duo left side view showing the audio and headphone outputs.
    • independent multi-stage preamplifiers per channel (+6, +15, +20dB);
    • TS connectors;
    • Input impedance 1 MΩ
    • Programmable Fine Adjust Gain Amplifier: ± 12 dB Gain, 0.5 dB step.
    • 24 bit Digital Audio convertion Bit Depth.
    • TRS noise cancelling;
    • TRS connectors (balanced compatible);
    • Volume Control: 0 to -127 dB, 0.5dB step;
  • Headphone output:
    • 6.35mm TRS connector
    • Digital volume control from +12dB to −33dB
  • MIDI IN connector - DIN 5 pins
  • MIDI OUT connector - DIN 5 pins
USB
  • USB HOST - USB 2.0 Standard-A type
    • USB Bluetooth
    • USB Wifi
    • USB MIDI
  • USB DEVICE - USB 2.0 Standard-B type
    • USB Ethernet Connection
    • USB Mass Storage (used for updates)
Controllers
  • 2 knobs with LCD screen
  • 2 footswitches with color LEDs
  • RJ-45 connector for additional controllers (see Control Chain)
Plugin Control
  • 2x endless knobs
    • up to 99 parameters can be assigned to each of the endless knobs
  • 2x Footswitches
    • a single parameter can be assigned to each footswitch
Peripherals
Software
