Bluetooth options
The controller has a menu option dedicated to Bluetooth. To access this menu please click and hold the left knob and scroll down to the "System" menu
Connecting using Bluetooth
In all cases, plug you Bluetooth dongle before turning the MOD device on.
Windows
3. Open the settings menu of your MOD device as described above.
5. Select your MOD device from the list and click 'Next'.
7. Select your MOD device icon and click 'Connect using' then 'Access point'
Mac OS
1. Turn on your MOD device and plug a Bluetooth USB dongle into it
2. Open the settings menu of your MOD device as described above.
3. Open System Preferences, go to Bluetooth and wait for your list to update. After a while you must see your MOD device appearing and available to connect
4. Click "Connect" for your MOD device and the list will be updated showing your device connected
5. That's it, your MOD device is connected. Open your browser and go to http://192.168.50.1/
2. Wait for it to boot
3. Open your MOD device settings menu (by holding the left knob down), go to the Bluetooth menu and enable discovery
4. Use your Bluetooth manager application to look for Bluetooth devices
5. Select your MOD device and connect to it
6. Join the Bluetooth network created by your MOD device
Connecting to mobile devices
Here we will let you know how to connect your MOD device via bluetooth with iOS and Android systems.
iOS
3. Go to Settings -> Bluetooth on your iOS device and wait until the MOD device appears on the list of "Other Devices"
4. Click on it and wait to connect.
5.You are now connected. Open your the browser on your mobile device and go to http://192.168.50.1/
Android
2. Enable the discover on the Bluetooth settings of your MOD device. On your Android device switch OFF the WLAN (WiFi) and switch ON the Bluetooth. Your MOD device must now appear on the list
3. Click on the MOD device name in order to pair it with your Android.
4. As soon as your MOD device is paired, click on its settings and activate the "Internet access" through it
Note: this will stop your access to your normal internet on this device.
5.You are now able to edit your pedalboard from your Android device. Open your the browser on your mobile device and go to http://192.168.50.1/
