MOD Duo User Guide
Headphone jack
General knob actions
Left knob actions
Right knob actions
General footswitch actions
- width: 180 mm
- length: 160 mm
- height: 74.7 mm
Hooking up the MOD Duo
Wiring examples
Guitar
- semi-accoustic setup
Vocals
- MIC -> MOD -> DI -> PA
Keys
- HW Synth -> MOD
- ePiano -> MOD
- keyboard -> MOD
- MIDI Grid-controller -> MOD
Exotic
TODO: Add exotic use cases
- Chapman stick
- Wind instruments
- Accoustic instruments
