Troubleshooting
For more information see Troubleshooting Windows Connection.
Can't connect to the Web GUI in my Mac OS
To check if that is the case, try to isolate the power of the MOD Duo X and see if it changes your results. One thing that helps is to make sure the MOD Duo X and all other equipment are connected to the same power socket.
References on Ground Loops:
MOD Duo X screens freeze
Site LOCAL
Accept from LOCAL
Deny
