Bluetooth options
The controller has a menu option dedicated to Bluetooth. To access this menu please click and hold the left knob and scroll down to the "System" menu
Connecting using Bluetooth
In all cases, plug you Bluetooth dongle before turning the MOD device on.
Windows
3. Open the settings menu of your MOD device (by holding the left knob down), go to the Bluetooth menu and enable discovery.
5. Select your MOD device from the list and click 'Next'.
7. Select your MOD device icon and click 'Connect using' then 'Access point'
Mac OS
1. Turn on your MOD device and plug a Bluetooth USB dongle into it
2. Open System Preferences, go to Bluetooth and wait for your list to update. After a while you must see your MOD device appearing and available to connect
3. Click "Connect" for your MOD device and the list will be updated showing your device connected
4. That's it, your MOD device is connected. Open your browser and go to http://192.168.50.1/
2. Wait for it to boot
3. Open your MOD device settings menu (by holding the left knob down), go to the Bluetooth menu and enable discovery
4. Use your Bluetooth manager application to look for Bluetooth devices
5. Select your MOD device and connect to it
6. Join the Bluetooth network created by your MOD device
