Bluetooth options
The controller has a menu option dedicated to Bluetooth. To access this menu please click and hold the left knob and scroll down to the "Settings" menu
Connecting using Bluetooth
In all cases, plug you Bluetooth dongle before turning the MOD device on.
Windows
3. Open the settings menu of your MOD device (by holding the left knob down), go to the Bluetooth menu and enable discovery.
5. Select your MOD device from the list and click 'Next'.
7. Select your MOD device icon and click 'Connect using' then 'Access point'
Mac OS
1. Turn on your MOD device and plug a Bluetooth USB dongle into it
3. Select your MOD device and click 'Continue'
5. After the setup finishes, connect to the MOD device Bluetooth network
2. Wait for it to boot
3. Open your MOD device settings menu (by holding the left knob down), go to the Bluetooth menu and enable discovery
4. Use your Bluetooth manager application to look for Bluetooth devices
5. Select your MOD device and connect to it
6. Join the Bluetooth network created by your MOD device
