MOD Web GUI User Guide
- 1 Accessing the GUI
- 2 Creating a pedalboard
- 3 Expanding Controls
- 4 True Bypass
- 5 CPU Usage
- 6 Settings
| MOD DUO | MOD DUO X |
- Pedalboard name
- Pedalboard actions bar
- Pedalboard assembler
- Plugins bar
| On the left edge of the assembler area (section 3) of the MOD DUO Web GUI there are 3 connectors: 2 audio inputs and 1 MIDI input. | On the left edge of the assembler area (section 3) of the MOD DUO X Web GUI there are 5 connectors: 2 audio inputs, 1 MIDI input, 2 CV inputs and 1 expression pedal input. |
| On the right edge (section 5) there are another 3 connectors: 2 audio outputs and 1 MIDI output. All those connectors represent the real inputs and outputs of your MOD DUO. | On the right edge (section 5) there are 5 connectors: 2 audio outputs, 1 MIDI output and 2 CV outputs. All those connectors represent the real inputs and outputs of your MOD DUO X. |
- Purple cables transport audio signals;
- Cyan cables transport MIDI signals;
Adding and connecting plugins
Adjusting plugins parameters
, settings
and delete
| Trigger | Yes | No | Yes |
Here you can:
in the mode selection bar.
In order to make it easy to access your pedalboards while the MOD device is disconnected from your PC, Mac or tablet, you can organize your pedalboards in banks. To access the banks configuration click on the banks icon
Installing new plugins
Sharing a pedalboard
Another great feature that the MOD devices have is allowing you to share and load pedalboards from the existing MOD online community. To share a pedalboard, go to the pedalboard assembler and click on the share
In addition to the classic MIDI ports you can also use the USB port to connect your MIDI controllers. Your MOD device will recognize your MIDI device when it is plugged in and add it to the MIDI ports list. Because a single MIDI device can have multiple ports, they are not visible in the assembler by default. To make them visible you will have to enable them first by clicking on the MIDI ports
button.
Preferences
