Troubleshooting
Can't connect to the Web GUI in my Mac OS
To check if that is the case, try to isolate the power of the MOD Duo X and see if it changes your results. One thing that helps is to make sure the MOD Duo X and all other equipment are connected to the same power socket.
References on Ground Loops:
MOD Duo X screens freeze
Site LOCAL
Accept from LOCAL
Deny
