MOD Web GUI User Guide
- 1 Accessing the GUI
- 2 Creating a pedalboard
- 3 Expanding Controls
- 4 True Bypass
- 5 CPU Usage
- 6 Settings
- Pedalboard name
- Pedalboard actions bar
- Pedalboard assembler
- Plugins bar
Adding and connecting plugins
Adjusting plugins parameters
and delete
Trigger | Yes | No | Yes |
Here you can:
In order to make it easy to access your pedalboards while the MOD Duo is disconnected from your PC, Mac or tablet, you can organize your pedalboards in banks. To access the banks configuration click on the banks icon in the mode selection bar.
Installing new plugins
Sharing a pedalboard
Another great feature that the MOD audio processors have is allowing you to share and load pedalboards from the existing MOD online community. To share a pedalboard, go to the pedalboard assembler and click on the share button in the pedalboard actions bar. Fill in the sharing dialog and (optionally) record a sample by clicking on the red circle. After finishing the recording, you can listen to it, or record it again. When you are done, click on the Share button.
In addition to the classic MIDI ports you can also use the USB port to connect your MIDI device. Your MOD unit will recognize your MIDI device when it is plugged in and add it to the MIDI ports list. Because a single MIDI device can have multiple ports, they are not visible in the assembler by default. To make them visible you will have to enable them first by clicking on the MIDI ports button.
Preferences
