MOD Web GUI User Guide
- 1 Accessing the GUI
- 2 Creating a pedalboard
- 3 Expanding Controls
- 4 True Bypass
- 5 CPU Usage
- 6 Settings
- Pedalboard name
- Pedalboard actions bar
- Pedalboard assembler
- Plugins bar
Adding and connecting plugins
Note that the inputs and outputs of the MOD Duo or Duo X are completely independent and can process multiple audio paths. The MOD Duo or Duo X allows you to create multiple connections coming out from the same output and also allows multiple connections to come in the same input. This feature allows the user to create complex pedalboards.
Adjusting plugins parameters
, settings
and delete
| Trigger | Yes | No | Yes |
Here you can:
- Enter the label that you would like to be displayed on the displays of your MOD Duo or Duo X
in the mode selection bar.
Installing new plugins
Sharing a pedalboard
Another great feature that the MOD audio processors have is allowing you to share and load pedalboards from the existing MOD online community. To share a pedalboard, go to the pedalboard assembler and click on the share
In addition to the classic MIDI ports you can also use the USB port to connect your MIDI device. Your MOD unit will recognize your MIDI device when it is plugged in and add it to the MIDI ports list. Because a single MIDI device can have multiple ports, they are not visible in the assembler by default. To make them visible you will have to enable them first by clicking on the MIDI ports
button.
Preferences
