- System: Access system-wide settings and information such as inputs and outputs gains, Bluetooth configuration and more.
- Sync & MIDI
- Bluetooth
- Info
- System Upgrade
PEDALBOARD NAV MIDI CHN
SHAPSHOT NAV MIDI CHAN
TODO
Name: Shows the name of your device in the Bluetooth network.
