  • Inputs
  • Outputs
  • Sync & MIDI
  • Bluetooth
  • Info
  • System Upgrade
CV / HP Output (Duo X): Select if this output port works either as an headphones or CV output.
PEDALBOARD NAV MIDI CHN
SHAPSHOT NAV MIDI CHAN
TODO
  • 0% (off)
  • 25%
  • 50%
  • 75%
  • 100%
