MOD Web GUI User Guide
Connect the MOD Duo or DUO X to your PC or Mac using the USB cable which you received with your MOD Duo OR Duo X. The operating system should recognize the MOD Duo or Duo X as a network device and configure it automatically. However, this process may fail in certain Windows versions, if that is your case please check the troubleshooting page.
Creating a pedalboard
  1. Pedalboard name
  2. Pedalboard actions bar
  3. Pedalboard assembler
  4. Plugins bar
  5. Mode selector (Assembler, Pedalboards, Banks and Store)
  6. Status bar (Device actions and information)
On the left edge of the assembler area there are 3 connectors: 2 audio inputs and 1 MIDI input. On the right edge there are another 3 connectors: 2 audio outputs and 1 MIDI output. All those connectors represent the real inputs and outputs of your MOD Duo or Duo X. Be aware that on the interface the signal flows from left to right.
  • Purple cables transport audio signals
  • Cyan cables transport MIDI signals
  • Orange cables transport CV signals.
Adding and connecting plugins
Note that the inputs and outputs of the MOD Duo or Duo X are completely independent and can process multiple audio paths. The MOD Duo or Duo X allows you to create multiple connections coming out from the same output and also allows multiple connections to come in the same input. This feature allows the user to create complex pedalboards.
Adjusting plugins parameters
To create an assignment, first click on the fader icon Gui-assign.png, found on the bottom-right corner of each parameter box, to open the assignment dialog box. Afterwards, select the actuator you would like to assign the parameter to from the dropdown list. The knobs can hold multiple assignments but footswitches can only hold one.
Bypass/Toggle Yes No Yes
Trigger Yes No Yes
Here you can:
  • Enter the label that you would like to be displayed on the displays of your MOD Duo or Duo X
  • Enter the range that you want the mapped actuator to sweep within, inverted ranges are also possible by setting the first parameter higher than the second parameter
  • Set the sensitivity (amount of steps from minimum to maximum) of the actuator from the dropdown menu
You have the possibility to save the combination of parameter adjustments as a pedalboard preset. In order to do so, turn on the pedalboard presets mode by clicking on the presets button Presets, positioned on the pedalboard actions bar.
In order to make it easy to access your pedalboards while the MOD Duo is disconnected from your PC, Mac or tablet, you can organize your pedalboards in banks. To access the banks configuration click on the banks icon Banks in the mode selection bar.
Installing new plugins
Sharing a pedalboard
Another great feature that the MOD audio processors have is allowing you to share and load pedalboards from the existing MOD online community. To share a pedalboard, go to the pedalboard assembler and click on the share Share pedalboard button in the pedalboard actions bar. Fill in the sharing dialog and (optionally) record a sample by clicking on the red circle. After finishing the recording, you can listen to it, or record it again. When you are done, click on the Share button.
In addition to the classic MIDI ports you can also use the USB port to connect your MIDI device. Your MOD unit will recognize your MIDI device when it is plugged in and add it to the MIDI ports list. Because a single MIDI device can have multiple ports, they are not visible in the assembler by default. To make them visible you will have to enable them first by clicking on the MIDI ports Gui-midi-ports.png button.
Preferences
  • Always start with playback/transport rolling: Automatically plays playback/transport when you turn your device on
  • Always start with Link support enabled:
  • Mute audio outputs when Tuner is enabled: Disables any audio output while you are using the Tuner
Advanced Settings
Device Updates
