MOD Web GUI User Guide
- 1 Accessing the GUI
- 2 Creating a pedalboard
- 3 Expanding Controls
- 4 True Bypass
- 5 CPU Usage
- 6 Settings
Connect the MOD Duo or DUO X to your PC or Mac using the USB cable which you received with your MOD Duo OR Duo X. The operating system should recognise the MOD Duo or Duo X as a network device and configure it automatically. However, this process may fail in certain Windows versions, if that is your case please check the troubleshooting page.
- Pedalboard name
- Pedalboard actions bar
- Pedalboard assembler
- Plugins bar
On the left edge of the assembler area there are 3 connectors: 2 audio inputs and 1 MIDI input. On the right edge there are another 3 connectors: 2 audio outputs and 1 MIDI output. All those connectors represent the real inputs and outputs of your MOD Duo or Duo X. Be aware that on the interface the signal flows from left to right.
Adding and connecting plugins
Note that the inputs and outputs of the MOD Duo or Duo X are completely independent and can process multiple audio paths. The MOD Duo or Duo X allows you to create multiple connections coming out from the same output and also allows multiple connections to come in the same input. This feature allows the user to create complex pedalboards.
Adjusting plugins parameters
and delete
Trigger | Yes | No | Yes |
Here you can:
- Enter the label that you would like to be displayed on the displays of your MOD Duo or Duo X
In order to make it easy to access your pedalboards while the MOD Duo is disconnected from your PC, Mac or tablet, you can organize your pedalboards in banks. To access the banks configuration click on the banks icon in the mode selection bar.
Installing new plugins
Sharing a pedalboard
Another great feature that the MOD Duo has is allowing you to share and load pedalboards from the existing MOD online community. To share a pedalboard, go to the pedalboard assembler and click on the share button in the pedalboard actions bar. Fill in the sharing dialog and (optionally) record a sample by clicking on the red circle. After finishing the recording, you can listen to it, or record it again. When you are done, click on the Share button.
In addition to the classic MIDI ports you can also use the USB port to connect your MIDI device. The MOD Duo will recognize your MIDI device when it is plugged in and add it to the MIDI ports list. Because a single MIDI device can have multiple ports, they are not visible in the assembler by default. To make them visible you will have to enable them first by clicking on the MIDI ports button.
Preferences
