  • Banks: Navigate your Banks of pedalboards.
  1. Sitch to the profile you want to overwrite
  • Inputs
  • Outputs
  • Sync & MIDI
  • Bluetooth
  • Info
  • System Upgrade
Stereo Link: If on, input gains for both channels will be linked and changes applied to one channel will also be applied to the other one.
CV / HP Output will be available in a future release to control the Headphone/CV output mode.
PEDALBOARD NAV MIDI CHN
SHAPSHOT NAV MIDI CHAN
TODO
  • 0% (off)
  • 25%
  • 50%
  • 75%
  • 100%
