Troubleshooting
Revision as of 13:38, 24 April 2020 by FalkTX (talk | contribs)
Can't connect to the Web GUI in my Mac OS
In short, ground loops may occur when you have multiple audio equipments grounded to different power sources but connected between each other. This situation can happen with Mod DuoX because it is a device that is actually referenced to earth.
To check if that is the case, try to isolate the power of the MOD DuoX and see if it changes your results. One thing that helps is to make sure the Mod DuoX and all other equipment are connected to the same power socket.
References on Ground Loops:
MOD Duo X screens freeze
Site LOCAL
Accept from LOCAL
Deny
