Troubleshooting Reinstall Duo
Revision as of 13:25, 24 April 2020 by FalkTX (talk | contribs)
Different MOD Duo models
A note on different models
Knowing which type of unit you have is important as the re-installation/reset procedure is not the same for each one.
For older Duo models:
For all Duo models:
Reinstall bootloader
  2. Hold it for 2 seconds, then release (The screens will freeze with the MOD logo and name)
If you're running macOS, run:
./bootfix.osx
./bootfix
MOD Duo Factory Reset
Continuing:
Reinstall via USB boot
  4. Download http://download.moddevices.com/releases/modduo/tools/mod-boot-fel-restore-v2.tar.gz and extract it
EMMC=1 ./boot-fel-restore.sh
MARS=1 ./boot-fel-restore.sh
For kickstarter units, run:
(NOTE: it might be possible that kickstarter units have the "MARS" model, and a non-kickstarter one not.
It is not possible to tell which kinda unit it is just by looking at it externally, so if the command with "MARS" does not work for you, try the one without and vice-versa.)
  1. After the script finishes, wait for around 2 minutes and the MOD Duo will boot into recovery mode.
  2. Install a MOD OS release as usual.
