Troubleshooting Reinstall
Different MOD Duo models
MOD boots the main system, but screens do not work
If the MOD is able to boot (verified by still providing USB Ethernet device) but the screens do not seem to work properly, we can try to re-flash the "top-board"/screen controller unit.
This is fixable through SSH, you simply connect to 192.168.51.1 (user 'root' and password 'mod') and then run the following command:
hmi-update /usr/share/mod/controller/mod*controller.bin
If your unit seems unable to boot properly, we can force the unit to start in restore mode.
  1. Turn off your MOD
  2. Hold the left knob and footswitch down (on the Duo X use the left endless-knob and the 1st button from the bottom-left)
  8. Disconnect the USB cable
MOD does not boot at all, not even in restore mode
This part of the troubleshooting section does not apply to the MOD Duo X, as it does not have a FEL button and thus cannot be forced to boot custom payloads.
For older Duo models:
For all Duo models:
Reinstall bootloader
  2. Hold it for 2 seconds, then release (The screens will freeze with the MOD logo and name)
If you're running macOS, run:
./bootfix.osx
./bootfix
MOD Duo Factory Reset
Continuing:
Reinstall via USB boot
  4. Download http://download.moddevices.com/releases/modduo/tools/mod-boot-fel-restore-v2.tar.gz and extract it
EMMC=1 ./boot-fel-restore.sh
MARS=1 ./boot-fel-restore.sh
For kickstarter units, run:
(NOTE: it might be possible that kickstarter units have the "MARS" model, and a non-kickstarter one not.
It is not possible to tell which kinda unit it is just by looking at it externally, so if the command with "MARS" does not work for you, try the one without and vice-versa.)
  1. After the script finishes, wait for around 2 minutes and the MOD Duo will boot into recovery mode.
  2. Install a MOD OS release as usual.
