How To Use Docker Toolbox With MPB
Pre-compiled image
$ cd mod-plugin-builder/dockerAfter that you can chose to either create an image for compiling plugins for the DUO, or for the DUO X.
To create a Duo image run:
$ docker build -t modduox-plugin-builder --build-arg platform=modduo .Or to create a Duo X image run:
$ docker build -t modduox-plugin-builder --build-arg platform=modduox .NOTE: This will take quite some time...
$ docker run -ti --name mpb -p 9000:9000 -v ~/local-mod-folder:/tmp/local-mod-folder mod-plugin-builder
