How To Use Docker Toolbox With MPB
Pre-compiled image
$ cd mod-plugin-builder/dockerAfter that you can chose to either create an image for compiling plugins for the DUO, or for the DUO X.
To create a Duo image run:
$ docker build -t modduo-plugin-builder --build-arg platform=modduo .Or to create a Duo X image run:
$ docker build -t modduox-plugin-builder --build-arg platform=modduox .NOTE: This will take quite some time...
After it's done, we create and run a container from modduo-plugin-builder or modduox-plugin-builder:
For Duo:
$ docker run -ti --name mdpb -p 9000:9000 -v ~/local-modduo-folder:/tmp/local-modduo-folder modduo-plugin-builder
$ exitOr for Duo X:
$ docker run -ti --name mdxpb -p 9000:9000 -v ~/local-modduox-folder:/tmp/local-modduox-folder modduox-plugin-builder
$ exitThat's it. The command to start the modduo-plugin-builder or modduox-plugin-builder environment is:
For Duo:
$ docker start -i mdpbOr for Duo X:
$ docker start -i mdxpb
