- System: Access system-wide settings and information such as inputs and outputs gains, Bluetooth configuration and more.
- Sitch to the profile you want to overwrite
- Sync & MIDI
- Bluetooth
- Info
- System Upgrade
Stereo Link: If on, input gains for both channels will be linked and changes applied to one channel will also be applied to the other one.
CV / HP Output will be available in a future release to control the Headphone/CV output mode.
PEDALBOARD NAV MIDI CHANNEL
SHAPSHOT NAV MIDI CHAN
The functionality is analogous to that of the PEDALBOARD NAV MIDI CHANNEL setting, but in respects to snapshots of the current pedalboard. At the moment, snapshots can't be reordered.
TODO
