CV Tutorial
Although only MOD Duo X has CV input and output, you are still able to use CV signals inside your pedalboard with any Mod device.
Getting Started
- CV: Use it as a CV input. Duo X CV input/output is unipolar positive, which means it reads/sends signals from 0 to 10V.
Note: When using an analog expression pedal, you might also have to adjust the "Expression pedal mode".
Inputs and outputs on the UI
Basic usage
Example 1 - SCREENSHOT - using an external CV controller (maybe simulating receiving a signal from a CV keyboard?)
Example 2 - SCREENSHOT using only CV internally to produce some sound
Using CV signals to control any parameter on your pedalboard
Let's see how to do this.
Click the "Manage CV Ports" button at the top of the screen:
2. Assign
3. Advanced Settings
- Range: Set the range that will be affected. By default, this brings the full range the plugin accept, but you can change it
Using CV Parameter Modulator
That's why we prepared the CV Parameter Modulator plugin.
Following our example, let's:
- Add the CV Parameter Modulator to our pedalboard
- Disable the LFO output port and enable the CV Parameter Modulator output port
- Change the assignment of the Depth parameter to the new enabled port
As we can see, CV Parameter Modulator has two parameters:
- PARAMETER: This defines modulates the signal coming in and sets its center value (IMPROVE THIS DESCRIPTION)
- MOD. DEPTH: This defines how much the input signal will be multiplied. If this parameter is at zero (center), the output will always be zero.
Now let's have a look at how is our result if we set the PARAMETER to 70% and the MOD. DEPTH to a small number, close to 10%:
