CV Tutorial
Although only MOD Duo X has CV input and output, you are still able to use CV signals inside your pedalboard with any Mod device.
Getting Started
- CV: Use it as a CV input. Duo X CV input/output is unipolar positive, which means it reads/sends signals from 0 to 10V.
Note: When using an analog expression pedal, you might also have to adjust the "Expression pedal mode".
Inputs and outputs on the UI
Basic usage
Example 1 - SCREENSHOT - using an external CV controller (maybe simulating receiving a signal from a CV keyboard?)
Example 2 - SCREENSHOT using only CV internally to produce some sound
Using CV signals to control any parameter on your pedalboard
Let's see how to do this.
Click the "Manage CV Ports" button at the top of the screen:
2. Assign
3. Advanced Settings
- Range: Set the range that will be affected. By default, this brings the full range the plugin accept, but you can change it
- Operational mode: Indicates what values this parameter expects from the CV source. This is automatically detected and, in most of the cases, you don't need to touch it. However, for more complex CV setups, you might want to change this.
Using CV Parameter Modulator
