CV Tutorial
Although only MOD Duo X has CV input and output, you are still able to use CV signals inside your pedalboard with any Mod device.
Getting Started
- CV: Use it as a CV input. Duo X CV input/output is unipolar positive, which means it reads/sends signals from 0 to 10V.
Note: When using an analog expression pedal, you might also have to adjust the "Expression pedal mode".
Inputs and outputs on the UI
Basic usage
Example 1 - using an external CV controller (maybe simulating receiving a signal from a CV keyboard?)
Example 2 - using only CV internally to produce some sound
Using CV signals to control any parameter on your pedalboard
Let's see how to do this.
Click the "Manage CV Ports" button at the top of the screen:
2. Assign
Using CV Parameter Modulator
