CV Tutorial
Although only MOD Duo X has CV input and output, you are still able to use CV signals inside your pedalboard with any Mod device.
Getting Started
- CV: Use it as a CV input. Duo X CV input/output is unipolar positive, which means it reads/sends signals from 0 to 10V.
Note: When using an analog expression pedal, you might also have to adjust the "Expression pedal mode".
Inputs and outputs on the UI
Basic usage
Example 1 - using an external CV controller (maybe simulating receiving a signal from a CV keyboard?)
Example 2 - using only CV internally to produce some sound
Using CV signals to control any parameter on your pedalboard
Using CV Parameter Modulator
