- System: Access system-wide settings and information such as inputs and outputs gains, Bluetooth configuration and more.
- Sitch to the profile you want to overwrite
- Sync & MIDI
- Bluetooth
- Info
- System Upgrade
Stereo Link: If on, input gains for both channels will be linked and changes applied to one channel will also be applied to the other one.
CV / EXP Input, CV Range and EXP Mode will be available in a future release to control the EXP/CV input.
CV / HP Output will be available in a future release to control the Headphone/CV output mode.
TODO
