Troubleshooting
- 4 Using Firefox and 'noscript' add-on prevents loading of cloud pedalboards
If the Duo becomes unbootable for some reason, we need to reinstall the OS inside.
We can boot the Duo in recovery mode for safe reinstall, boot over USB if recovery partition is broken, or perform a full factory reset (which will erase all your data).
In short, ground loops may occur when you have multiple audio equipments grounded to different power sources but connected between each other. This situation can happen with Mod DuoX because it is a device that is actually referenced to earth.
To check if that is the case, try to isolate the power of the MOD DuoX and see if it changes your results. One thing that helps is to make sure the Mod DuoX and all other equipment are connected to the same power socket.
References on Ground Loops:
