MOD Web GUI User Guide
- 1 Accessing the GUI
- 2 Creating a pedalboard
- 3 Expanding Controls
- 4 CPU Usage
- 5 Settings
For the MOD Duo X: http://modduox.local or http://192.168.51.60.
- Pedalboard name
- Pedalboard actions bar
- Pedalboard assembler
- Plugins bar
Adding and connecting plugins
Adjusting plugins parameters
, settings
and delete
| Trigger | Yes | No | Yes |
Here you can:
in the mode selection bar.
Installing new plugins
Sharing a pedalboard
Another great feature that the MOD Duo has is allowing you to share and load pedalboards from the existing MOD online community. To share a pedalboard, go to the pedalboard assembler and click on the share
In addition to the classic MIDI ports you can also use the USB port to connect your MIDI device. The MOD Duo will recognize your MIDI device when it is plugged in and add it to the MIDI ports list. Because a single MIDI device can have multiple ports, they are not visible in the assembler by default. To make them visible you will have to enable them first by clicking on the MIDI ports
button.
Preferences
This feature allows you to make a backup of all your data to later recovery. You can backup Banks, Pedalboards, Device configuration (such as audio gains, bluetoothe config, etc) and all the plugins you have downloaded.
