Troubleshooting Reinstall
Different MOD Duo models
  1. Turn off your MOD
  2. Hold the left knob and footswitch down (on the Duo X use the 1st button from the bottom-left)
  8. Disconnect the USB cable
MOD does not boot at all, not even in restore mode
This part of the troubleshooting section does not apply to the MOD Duo X, as it does not have a FEL button and thus cannot be forced to boot custom payloads.
For older Duo models:
For all Duo models:
Reinstall bootloader
If you're running macOS, run:
./bootfix.osx
./bootfix
MOD Duo Factory Reset
Continuing:
Reinstall via USB boot
  4. Download http://download.moddevices.com/releases/modduo/tools/mod-boot-fel-restore-v2.tar.gz and extract it
For the MOD Duo 2020 unit, run:
  1. EMMC=1 ./boot-fel-restore.sh
  1. MARS=1 ./boot-fel-restore.sh
For kickstarter units, run:
  1. ./boot-fel-restore.sh
(NOTE: it might be possible that kickstarter units have the "MARS" model, and a non-kickstarter one not. It is not possible to tell just by looking at the unit externally, so if the command with "MARS" does not work for you, try the one without, and vice-versa.)
  1. After the script finishes, wait for around 2 minutes, and the MOD Duo will boot into recovery mode.
  2. Install a MOD OS release as usual.
