This page is under construction and applies to devices on version 1.7+
- System: Access system-wide settings and information such as inputs and outputs gains, Bluetooth configuration and more.
- Sitch to the profile you want to overwrite
Stereo Link: If on, input gains for both channels will be linked and changes applied to one channel will also be applied to the other one.
TODO
