Troubleshooting Reinstall
- Turn off your MOD
- Hold the left knob and footswitch down (on the Duo X use the 1st button from the bottom-left)
- Disconnect the USB cable
This part of the troubleshooting section does not apply to the MOD Duo X, as it does not have a FEL button and thus cannot be forced to boot custom payloads.
For older Duo models:
For all Duo models:
Reinstall bootloader
If you're running macOS, run:
./bootfix.osx
./bootfix
MOD Duo Factory Reset
Continuing:
Reinstall via USB boot
For all units and models
Continuing:
- Run:
