Troubleshooting Reinstall
- Turn off your MOD
- Hold the left knob and footswitch down (on the Duo X use the 1st button from the bottom-left)
- Disconnect the USB cable
For older models:
For all models:
Reinstall bootloader
If you're running macOS, run:
./bootfix.osx
./bootfix
MOD Duo Factory Reset
For a factory reset under Windows, see Troubleshooting_Reinstall_via_LiveSuit. (also applies only to MOD Duo units with nand flash)
Continuing:
Reinstall via USB boot
Continuing:
- Run:
