Revision as of 11:46, 11 September 2019 by Leogermani (talk | contribs) (→‎Outputs)
This page is under construction and applies to devices on version 1.7+
SCREENSHOT -> Settings Menu (left screen)
SCREENSHOT -> both screens in the Banks menu
Scroll the options in the main menu by rotating the left knob. Some options have a toggle indicator that can be triggered by quick pressing the left knob. These options have a "[ ]" or "[x]" indicating the state of the toggle. For example, the Hardware Bypass can be turned on or off by pressing the left knob.
SCREENSHOT -> third level menu. Output or input settings
SCREENSHOT -> Banks (both screens)
Press the right knob to enter a bank and navigate it's pedalboards. Press the right knob again to select and activate a pedalboard.
You can organize your banks anyway you wanto using the Web GUI interface.
Changing pedalboards using the footswitches
TODO: Check if this is a MOD Duo specific feature
When Foot Navigation is on, The Footswitches will navigate to the next or previous pedalboard in the current bank. Left footswitch will load the previous pedalboard, and the right footsitch will load the next.
SCREENSHOT -> Current pedalboard menu
SCREENSHOT -> Hardware bypass (both screens)
SCREENSHOT -> Tempo & Transport (both screens)
SCREENSHOT -> Tuner (both screens)
SCREENSHOT -> User Profiles menu (both screen)
SCREENSHOT -> change profile confirmation screen
  1. Sitch to the profile you want to overwrite
SCREENSHOT -> overwrite user profile confirmation
SCREENSHOT -> System menu (right screen)
SCREENSHOT -> Inputs settings
Stereo Link: If on, input gains for both channels will be linked and changes applied to one channel will also be applied to the other one. Input 1 and Input 2 Gain: Navigate to one of these options and press the right knob to select which one you want to change. Turn the knob to change the value and press it again to exit edit mode.
SCREENSHOT -> outputs settings
Stereo Link: If on, output volumes for both channels will be linked and changes applied to one channel will also be applied to the other one. Output 1, Output 2, and Headphone Volume: Navigate to one of these options and press the right knob to select which one you want to change. Turn the knob to change the value and press it again to exit edit mode.
SCREENSHOT -> Sync & MIDI settings
TODO
SCREENSHOT -> system Bluetooth
SCREENSHOT -> bluetooth discovery confirmation
SCREENSHOT -> Display brightness
  • 0% (off)
  • 25%
  • 50%
  • 75%
  • 100%
Services: The status of the different services running Versions: Version of MOD software Device: The serial number of your device
SCREENSHOTS -> each screen in info
