Troubleshooting Reinstall
- Turn off your MOD
- Disconnect the USB cable
For older models:
For all models:
Reinstall bootloader
If you're running macOS, run:
./bootfix.osx
./bootfix
MOD Duo Factory Reset
For a factory reset under Windows, see Troubleshooting_Reinstall_via_LiveSuit. (also applies only to MOD Duo units with nand flash)
Continuing:
- If the LEDs are still blue for too long (actually they go to red and then return to blue) or the display shows the message "copy file, eject and unplug", please execute all this process again starting from the bootfix command.
Reinstall via USB boot
Continuing:
- Run:
