Troubleshooting Reinstall
  1. Turn off your MOD
  2. Hold the left knob and footswitch down
  4. Wait 5 seconds and let go of the knob and footswitch
  7. Copy the modduo*.tar file onto the new drive and use your OS option to safely remove the drive
  8. Disconnect the USB cable
This method is only possible for MOD Duo units; if you have a MOD Duo X unit that cannot boot normally or in forced-restore mode, please contact [emailto:support@moddevices.com support@moddevices.com].
For older models:
For all models:
Reinstall bootloader
If you're running macOS, run:
./bootfix.osx
./bootfix
Factory Reset
Continuing:
  • If the LEDs are still blue for too long (actually they go to red and then return to blue) or the display shows the message "copy file, eject and unplug", please execute all this process again starting from the bootfix command.
Reinstall via USB boot
  4. Download http://download.moddevices.com/releases/modduo/tools/mod-boot-fel-restore.tar.gz and extract it
Continuing:
  1. Run: ./boot-fel-restore.sh
