This page is under construction and applies to devices on version 1.7+
- System: Access system-wide settings and information such as inputs and outputs gains, Bluetooth configuration and more.
SCREENSHOT -> Settings Menu (left screen)
SCREENSHOT -> both screens in the Banks menu
Scroll the options in the main menu by rotating the left knob. Some options have a toggle indicator that can be triggered by quick pressing the left knob. These options have a "[ ]" or "[x]" indicating the state of the toggle. For example, the Hardware Bypass can be turned on or off by pressing the left knob.
SCREENSHOT -> third level menu. Output or input settings
SCREENSHOT -> Current pedalboard menu
SCREENSHOT -> Hardware bypass (both screens)
SCREENSHOT -> Tempo & Transport (both screens)
SCREENSHOT -> Tuner (both screens)
Note: You can quickly access the Tuner by pressing and holding the right-hand knob any time.
When you quick access the Tuner by pressing and holding the right knob, you have to press and hold the same knob again to exit.
SCREENSHOT -> User Profiles menu (both screen)
SCREENSHOT -> change profile confirmation screen
- Sitch to the profile you want to overwrite
SCREENSHOT -> overwrite user profile confirmation
SCREENSHOT -> System menu (right screen)
SCREENSHOT -> Inputs settings
Stereo Link: If on, input gains for both channels will be linked and changes applied to one channel will also be applied to the other one. Input 1 and Input 2 Gain: Navigate to one of these options and press the right knob to select which one you want to change. Turn the knob to change the value and press it again to exit edit mode.
SCREENSHOT -> outputs settings
Stereo Link: If on, output volumes for both channels will be linked and changes applied to one channel will also be applied to the other one. Output 1, Output 2, and Headphone Volume: Navigate to one of these options and press the right knob to select which one you want to change. Turn the knob to change the value and press it again to exit edit mode.
SCREENSHOT -> Sync & MIDI settings
TODO
SCREENSHOT -> system Bluetooth
SCREENSHOT -> bluetooth discovery confirmation
SCREENSHOT -> Display brightness
Services: The status of the different services running Versions: Version of MOD software Device: The serial number of your device
SCREENSHOTS -> each screen in info
